Angle tool
Angle tool
Angle tool
I want to measure the slope of this from apex and from a side. How to measure using angle tool.
SBix26
Others may have a better answer, but I normally just start a sketch on a plane through the center (one of your origin planes if you modeled it around the center), project geometry and measure the angle.  Then undo to eliminate the new sketch.
Or, throw it in a drawing temporarily and measure there.
I have great expectations for the revamped Measure tool... !
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
There is a way to measure: go to sketch and then slice tool. But I want to measure it by using angle tool.
CCarreiras
You want, but you can't...
...because a angle measurement must be made between two plane faces.... you don't have that, rigth?
workaround...do the sketch.
CCarreiras
