Angle parameter gets changed and breaks my part when publishing a custom elbow to the content center to use in Tube & Pipe environment.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working in a Vault project and trying to model a plumbing system with custom fittings. I've successfully modeled and published 4 or so fittings without this problem, including another elbow with an angle parameter.
I have a User Parameter called ANGLE that is set to 90, with unit set to deg. I then author the part and publish it to content center and when I go to place it in my assembly through the Tube & Pipe environment, my 90deg elbow is straight and has broken geometry. When I place the elbow and open it up, I go to my user parameter and the unit is still set to degrees, but the value is now set to 1.57......... which is 90deg in radians.
This seems like a bug because I followed the same process as the other elbow I published without error.
Does anybody have any advice?
