Angle in drawing
Angle in drawing
hartingsveldt
Angle in drawing
hartingsveldt
How can I get the actual bend angle in my bend annotations in a flat pattern drawing? I did the following, but to no success...
emanuel.c
I think you just need to use "Bend" Under Annotate Tab -> Feature Notes. Is this what you're looking for?
hartingsveldt
Yeah that's the function i'm using, the problem is my bends are all annotated incorrectly. A 100° bend is annotated as an 80° bend and a 110° bend will be annotated as a 70° bend.
emanuel.c
Then you might need to modify the "Report Bending Angle". Go to your sheet metal part and find it under the Styles.
hartingsveldt
Worked, thanks Emanuel!
