Angel in Sketch
Angel in Sketch
Angel in Sketch
How can idefine angle between to line as degrees, minutes and seconds?
Is it possible? Thanks
mdavis22569
Take a look at:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
Mike Davis
Curtis_Waguespack
Hi Mirza1ghasemi,
In a part or assembly sketch, I don't think you can. Can you confirm that you are looking to do this in a part or assembly model?
edit: see mdavis22569's reply about typing it in as DMS
@mdavis22569 that is only for drawing dimensions, no?
I hope this helps.
Curtis
mdavis22569
yes..
However ... you can put DMS in the dimension ... it will convert it to degreesdms.PNG
unfortunately the Document settings doesn't give you the option to set it to DMS.
Just Degree and Radian
Mike Davis
Curtis_Waguespack
@mdavis22569 wrote:
... you can put in the dimension ... it will convert it to degrees
Nice! I didn't know that could be done, and never thought to try it.
