Alignment problem
Alignment problem
jnewstedt
Alignment problem
jnewstedt
When I make a simple rectangle, I am unable to use Vertical Constraint to center it to the plane. I get an error: "Adding this constraint will over-constrain the sketch."
What is wrong?
andrewdroth
Try a horizontal constraint? Sometimes they are switched. Are you constraining to the mid-point of the line?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
mcgyvr
Post an ipt file that generates that error..
jnewstedt
It's really any file I try this with.
I've attached a screencast to illustrate what's happening.
jnewstedt
Sorry! Sorry, I realised I need to click the center of the line in order for the program to consider it for alignment to the plane.
Thanks for your interest, both of you.
jnewstedt
Clicking the center of the line was my problem. Thanks for the help!
