Align drawing views to the bottom (not the centre) of view
Message 1 of 14
Does anyone know any way to align 2 or more drawing views to the bottom of the view not the middle of the view?
See the screenshot below of what I am trying to achieve:
I have just roughly positioned these 2 drawing views by eye. I want them to be exactly aligned along the bottom so that the castors would all sit along a straight line.
Thanks for any help,
Finn
Replies (13)
Message 2 of 14
Mark.Lancaster
@Anonymous
If you right mouse click on a given view and select alignment from the contextual menu.
Mark Lancaster
Message 3 of 14
Cadmanto
The alignment command does not give you the option to choose an edge to align to.
Take a look at this thread.  It speaks to what you are looking for and has a link to an idea to enhance the alignment command to do what you are asking.
https://forums.autodesk.com/t5/inventor-forum/view-alignment/td-p/6209545
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 14
Cris-Ideas
If this is the same assembly you can get that but with a workaround
Have two views of the assembly in the same POS REP.
Change view setting from centred to fixed
Brake out alignment.
Change POS REP in the view you want.
Cris.
Cris,
https://simply.engineering
Message 5 of 14
Problem solved
As it was the same assembly but different positional representations that I wanted to line up I could use the workaround that Cris suggested.
Cheers mate, appreciate it.
I have also added to that thread so hopefully it may get changed in the future. I am surprised that there aren't more users with this problem.
Message 6 of 14
Cris-Ideas
There are but Autodesk only does what it thinks is needed and fixing bugs and removing stupid limitations is not high on their list.
So people just quite trying. and either leave or live with it.
Workaround I gave, you can also use in other situations but this requires additional tricks if you want to align different assemblies or parts.
Cris
Cris,
Message 7 of 14
rayessle
You could try adding and running this ilogic rule.
1. pick the view you want to keep in position.
2. pick the view you want to align. the view will move in the vertical direction to align both bottom edges of the views.
oView1=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select the a view to retrieve position of")
pt1 = oView1.Position
'MsgBox("X: " & pt1.X & vbLf & "Y: " & pt1.Y)
ht1= oView1.Height
oView2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select the a view to align position of")
pt2 = oView2.Position
ht2 = oView2.height
ActiveSheet.View(oView2.name).SetCenter(pt2.X * 10, (pt1.Y - (ht1/2) + (ht2/2))*10)
Message 8 of 14
Thanks a lot Ray, that tool works perfectly!
Finn
Message 9 of 14
SER4
I'm running 2019.  Does this iLogic work for anyone else?
The 2nd drawing view selected seems to become hidden (still an entry in the browser though).
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
Message 10 of 14
rayessle
Are you using this on an 'imperial' ie not metric drawing sheet? Just tried it and it works on the metric drawing sheets in 2020 but not the imperial ones.? It does actually move the view but puts it off the drawing sheet (outside the border) Will try to work out why.
Message 11 of 14
rayessle
Changing the 10 factor to 10/25.4 seems to work.
ht1= oView1.Height
ht2 = oView2.height
ActiveSheet.View(oView2.name).SetCenter(pt2.X * 10/25.4, (pt1.Y - (ht1/2) + (ht2/2))*10/25.4)
Message 12 of 14
SER4
Not to discredit your work, @rayessle, but I have found the following forum thread in which you can align views by lines (e.g. sketch lines), which is very helpful for more than just vertical & horizontal (e.g. triple axisymmetric).
https://forums.autodesk.com/t5/inventor-forum/aligning-views-to-a-line/td-p/7186354
Message 13 of 14
kadscad
SOME ONE THAT KNOW HOW TO CODE NEEDS TO FIX THIS
Kirk
Inventor 2023
Message 14 of 14
johnsonshiue
Hi! Please see my latest reply to your message.
https://forums.autodesk.com/t5/inventor-forum/view-alignment/m-p/11800047/highlight/false#M889925
Many thanks!
Software Test Engineer
