Align 2 holes together
Hi everybody
There are two parts in the assembly with 2 holes, one on part A and the other one on part B. They are align to gether.
How can I do this?
If hole on part B moves to new position, I want the hole on part A also moves to the new position, align with the hole on part B.
Best Regards,
IgorMir
Just out of curiosity - do you work for someone using Inventor or are you learning it yet?
Web: www.meqc.com.au
Sergio.D.Suárez
Hello, welcome to the forum. Here I show you a video with two examples. The first the easiest, you must have the boxes checked within assembly options as shown in the video to allow the associativity between the parties.
The second method is through a derived piece. A base part is derived inside the other, it is relocated and the hole is projected on the new part, finally it is extruded. When the assembly is created, note that the two parts are placed in assembly as "place gorunded at origin" (right click on the graphic window to select it)
There are other methods to achieve your goal, such as multibody, but these methods I think would be useful.
Best regards!!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
