Inventor Forum
AIP 2013 | Tempates Network
3 REPLIES 3
300 Views, 3 Replies
(AIP - 2013)  I put my templates on a central workstation. I configured the project files (.ipj) on the other computers (folder options-templates) When I click 'new' to start a part or what ever, the templates are not found. The dialogbox is empty. I also tried to change the standard location for the templates. (appl.options - file - templates) Same result, the templates are not found. Please help. (AIP 2012 works ok)
3 REPLIES 3
blair
Not knowing much about your network, but you would have better luck setting up your templates directory on your server.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
As I said, the AIP 2012 release worked perfect. Just a simple network, should working without any problem.Why not after installing 2013? Clean install of course.
SBix26
Starting two threads with the same subject is bound to lead to confusion...
Check out this post and final answer.
