Inventor Forum
AIP 2013 | Tempates Network
3 REPLIES 3
info
292 Views, 3 Replies
(AIP - 2013)  I put my templates on a central workstation. I configured the project files (.ipj) on the other computers (folder options-templates) When I click 'new' to start a part or what ever, the templates are not found. The dialogbox is empty. I also tried to change the standard location for the templates. (appl.options - file - templates) Same result, the templates are not found. Please help. (AIP 2012 works ok)
3 REPLIES 3
blair
in reply to: info
Not knowing much about your network, but you would have better luck setting up your templates directory on your server.
Delta Tau Chi ΔΤΧ
info
in reply to: info
As I said, the AIP 2012 release worked perfect. Just a simple network, should working without any problem.Why not after installing 2013? Clean install of course.
SBix26
in reply to: info
Starting two threads with the same subject is bound to lead to confusion...
Check out this post and final answer.
