Inventor Forum
Welcome to Autodeskโ€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Additional driven dimention during piping and tubing
2 REPLIES 2
adrianaarsland
300 Views, 2 Replies
Hello! ๐Ÿ™‚
I've recently started using tubing and piping in inventor. I've noticed that whenever I start a tube run and place the first piece of tube, I get the dimension of the length (in this case 52mm), and then I get an additional ''Driven dimension'' displayed like: (52).
What is this driven dimension good for? And if there is no use for it, is there a way disable them from appearing?
โ€ƒThank you in advance ๐Ÿ™‚
2 REPLIES 2
I have used T&P extensively and I know that the Normal dimension is the user-input dimension (whatever length you defined in the route sketch). According to Autodesk the driven dimension is used for "dynamic updates" but I cannot say that I have ever worked with this feature (although I am sure others here have). To my knowledge there is no way to turn it off...
Alright, thank you! Nothing of major importance then I guess ๐Ÿ˜„
