adding z coordinates to a 2d sketch curve
Dear people,
I am quite new to inventor and am quite familiar with tools like grasshopper (rhino)
Today I tried to do something that is possible in the latter software and might not be possible in inventor. Thats why I ask you for help.
Assume I have a 2d curve(sketch) that is composed of arcs and straight parts. Then I want to add z-coordinate information to this curve. To be specific I want a linear decline of the z coordinate between the beginning and end of the curve. E..g 0 at the start and 9000mm at the end. Is there a way to add a z transformation to the whole curve to create the above effect? Or am I going at it the wrong way?
Hope you can help,
Elmar
JDMather
You are describing a 3D Sketch, not a 2D Sketch.
But what is your end goal?
Do you have a link or image of something similar to what you are trying to do?
Maybe you do want a 2D Sketch, but you simply want it on an inclined plane.
Can you attach your *.ipt file here?
Have you gone through the Getting Started Tutorials?
WHolzwarth
Jeffrey, IMO he's after something like this. (2016 file attached)
Smiley Wink Thanks for your basic sketch.
Walter
Walter Holzwarth
JDMather
....or maybe this technique?
Note that this is not the same gradual rise path as Walter demonstrated.
Just a different way of what I posted in my original response.
WHolzwarth
I don't think so. I'm pretty sure, that he's wanting a steady climb-up along the path.
Walter Holzwarth
JDMather
Yes, I realized that my "solution" was "wrong" after I posted.
This is exactly what I had in mind! thank you very much 😄
