Adding Prefix to Body Name
Biju.Veedu
Biju.Veedu
Hi All,
Is there any ilOGIC rules avaiable to add prefix to all solid bodies in a multibody part file?  i want to retain the existing solidbody name with new prefix infront of it. thanks.
A.Acheson
@Biju.Veedu
The below post are all duplicate post requesting the same thing.
https://forums.autodesk.com/t5/inventor-customization/ilogic-rename-solid-bodies-all-to-select/m-p/1...
https://forums.autodesk.com/t5/inventor-forum/adding-prefix-to-body-name/m-p/10424069
https://forums.autodesk.com/t5/inventor-customization/multi-bodies-auto-rename/m-p/10424080#M125900
Firstly please avoid creating duplicate posts this can be very frustrating for users and will dilute the effectiveness of individual post. Secondly  it is better to create one post and link other post that explain your help request. Thirdly posting on solved posts is also not the best practice as user will assume they are solved and will pass over them.
For future post if they involve ilogic please post them here.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
If possible include the code you are working with/attempted and an explanation of the problem.
The below code is adapted from here on post 20 0f 32
withString = InputBox("Prompt", "Title", "Default Entry")
	For Each solid In ThisDoc.Document.ComponentDefinition.SurfaceBodies
		Name = solid.Name
		myparams = Name.Split("-")
		replaceString1 = myparams(0)
		'replaceString2 = myparams(1)
		Name = Name.Replace(replaceString1, withString)
		solid.Name = Name
 	Next
Regards
Alan
gcoombridge
In a part file you can do this without code for all future solids under document settings
Otherwise here is some code:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSolid As SurfaceBody
Dim oSolidName As String
Dim oPrefix As String = InputBox("Provide a prefix for each solid:", "Solid Body Prefix","")
'iterate through all solids and rename if default
For Each oSolid In oDef.SurfaceBodies
	oSolidName = oSolid.Name
	oSolid.Name = oPrefix & oSolidName
Next oSolid
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Biju.Veedu
Excellent.
also By changing the code slightly i could use this to rename existing bodies that are in different naming formats.
for example i used "_" &  "space" to replace.  anyway great. thankyou.
Biju.Veedu
Excellent. thankyou.
this code helped me to rename with a new prefix.
here is the code for replacing an existing name that are seperated by "_"
		Name = solid.Name
		myparams = Name.Split("_")
		solid.Name = Name
 	Next
