Announcements
adding new hotkeys
adding new hotkeys
how can i a new hotkey or shortcuts for a new command assign; for example there is no shortcuts for dimension, how could i assign a shortcut for it although it has no shortcut
thanks in advance
Replies (8)
Xun.Zhang
Howdy @Anonymous  I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Try to right mouse click on the Ribbon to bring up Customize user commands... and go to Key tab, find the command and try to assign shortcuts there.
Hope it helps!
Xun
I do thank you for you quick response .The problem is the command dimension is not existed in this list.And my question is how to add this command to keyboard list and then i can assign the desired shortcut
Thanks a lot in anticipation
Xun.Zhang
Refer to below image and hope it helps!
Xun
Thanks a lot
mcgyvr
@Anonymous  The Command Name is actually "General Dimension"...  Thats what you want and that is typically the "D" key by default when in a sketch
Its also NOT in the "Sketch" category if you were looking for it there.. Its in the "Dimension" category as it applies to inside of part sketches/drawing sketches and directly at the drawing annotation level.
Wynand_Louw_Aranzu
OK, so how do I create a shortcut, as what I'm looking for is not in the lists? I whant to quick swap between a gradiented background to a 1 colour background to do a quick screenshot, and then switch back again.
HotkeyAddict
Observer
Observer
Hi @Wynand_Louw_Aranzu
I hope this can be useful.
I`m using Inventor 2024 and have activated “Use default multi-character Command Aliases”
Some commands have shorter/different names in the customize menu.
For example, the “Insert Sketch Symbol” is just named “Symbols” in the customize menu.
I found out by hovering over the “Insert Sketch Symbol” until a dropdown menu appeared telling me that it already had the hotkey (keyboard shortcut binding) SY.
Question: If someone know a fast way to directly add specific sketch symbols form my local folder to a drawing, please let me know.
CGBenner
@HotkeyAddict
Welcome to the forum, and thank you for adding to this thread.  I see that you also added a new question at the bottom of your post.  I suggest posting this question in a new forum post so that it will be seen by more people.  Have a good day.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
