Adding a chamfer in thread.xml file
julio.romerodarocha
julio.romerodarocha
Hi all
Somebody know if it´s possible to add information about  the dimension of a chamfer for a tapped hole in the excel file (thread.xml) to make possible that Inventor creates a thread with chamfer automatically for each differents Metrics, BSW,G,UNC or whatever thread, only selecting the thread type?
For example: M16_____hole dim=14/deep thread=25/deep drill=35/ Chamfer=18mm
SBix26
That would only be possible with coding, either by user (iLogic, add-in) or by Autodesk.
For what it's worth, the file you are referring to is thread.xls, not .xml
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
julio.romerodarocha
Hi
Yes, .xls, it was my fault.
