Message 1 of 16
12:33 PM
I'm trying to model a cable whip between a fixed point and a moving end of an actuator. I make the cable whip adaptive and do a loft or sweep to a point on the moving arm and everything appears to work correctly. However, once I move the arm, the work plane moves off in another direction. It's like the work plane isn't constrained to the face I created it on. When I try to "redefine it" it stays put and won't update to the new position. The yellow circle is the intended landing spot for the sweep.
