Activate Level of Detail - Greyed Out
andrew_canfield
andrew_canfield
Hello
What can cause this?
the LoD can't be changed..
Regards
Andrew
Replies (7)
mdavis22569
You're in Express view, what if you go Full?
Mike Davis
andrew_canfield
Not sure why but it's started working.
This occurring though..
mdavis22569
I would turn off that add-in and then test it.
Can you share it?
Mike Davis
Mark.Lancaster
@andrew_canfield
Are you still in Express Mode or did you load full (your model)?
If you're still in Express mode and started interacting with your model, only certain things get loaded into memory when you do that.
The message indicates the bonus tool of linking your LODS together is unable to function.  I'm assuming its based on since a portion of your model is still considered in Express Mode.
If you don't know how express mode works I would either disable it in your application options or research it (https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...).
Mark Lancaster
mdavis22569
That's what I was thinking and asking earlier .... @andrew_canfield can you try doing it in Full Mode?
Mike Davis
andrew_canfield
I didn't realise it had switched to express mode - retesting with it switched off.
Regards
Andrew
mdavis22569
That should get you back to normal ....
Mike Davis
