Access Material property fields via iProperty expression?
Wondering what the field names for the properties within a material would be and what the expression would be to enter into and an iProperty. So for example below I would assume something like =<material.comments> but that doesn't seem to work.
pball
There might not be a way to access that. I tried looking for a way to access that with the vba api and couldn't find a method to reference it that way either.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
HermJan.Otterman
This iLogic rule will set the values for the active material in a part.
      Dim oPartDoc As Inventor.PartDocument = ThisApplication.ActiveDocument
        Dim comments As StringAssetValue = oPartDoc.ActiveMaterial("physmat_Comments")
        comments.Value = "Comments"
        Dim manufacturer As StringAssetValue = oPartDoc.ActiveMaterial("physmat_Manufacturer")
        manufacturer.Value = "HJ"
        Dim model As StringAssetValue = oPartDoc.ActiveMaterial("physmat_Model")
        model.Value = "2017"
        Dim cost As StringAssetValue = oPartDoc.ActiveMaterial("physmat_Cost")
        cost.Value = "nothing"
        Dim url As StringAssetValue = oPartDoc.ActiveMaterial("physmat_URL")
        url.Value = "www.cadac.com"
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
pball
It's nice to be proven wrong. I also learned a new trick and to try digging deeper for properties.
Hello guys!
Is it possible to get these information using ILogic from oDocument.ActiveAppearance as well?
Like the Description or Keywords
Best Regards. Aron
johnsonshiue
Hi! ActiveAppearance() is considered a property of Asset. There are other properties like "Name", "DisplayName", and "CategoryName." Please take a look at Inventor Programming Help. There is good information there.
Many thanks!
Software Test Engineer
