Accelerating ANYCAD Importing with Inventor (DELETE OTHER POST)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please delete the other post, I did not realize that it was still in the IT account.
We receive these ANYCAD format files (STEP, IGS, X_T, etc.) and I have been thinking that I can automate my clicks.
I think VBA editor or Macros (based on what they can do in MS Office products) are the go-to instead of iLogic since I am looking to record clicks (if even possible). Most of these are assemblies that I would be working with, so the example I show will be what I am doing for IAM files.
Regardless, the flow is like this for solid body component files:
->Import as Inventor file (IAM)
->Ground all components
->Open component and navigate to Document Properties
->Set Linear Units as desired
->Set Angular Units as desired
->Set Linear Precision as desired under Modelling Dimension Display Category
->Set Angular Precision as desired under Modelling Dimension Display Category
->Toggle dimension view to Display precise value under Modelling Dimension Display Category
For surface model parts, the flow is like this:
->Open component and perform Surface Repair when required
->Navigate to Document Properties
I imagine that one of Inventor's features should allow this to happen. Conversely, if this is not really possible, it would seem like I would need to create iLogic or VBA for those singular aspects outlined above, and just run those individually?
- HP OMEN 40L Tower
- Windows 11 Pro - 64-bit 24H2
- AMD Ryzen 7 5800X @ 3.80 GHz
- 48 GB RAM
- AMD Radeon RX 6600 XT 8GB
- Inventor 2024 Professional & Vault Basic installed on M.2 SD
- Window Defender
Remote Machine Specs:
- HP Z2 Mini G4
- Windows 10 Pro - 64-bit
- Intel Core i9-9900 @ 3.10 GHz base
- 32 GB RAM
- NVIDIA Quadro P1000 4GB
- Inventor 2024 Professional & Vault Basic installed on M.2 SSD
- Windows Defender
