About updating Add-ins
FINET_Laurent
FINET_Laurent
Dear all, bonjour.
I would like to gather your experience to take the correct decision regarding the way I will manage my add-ins deployement. Indeed, I developped over the years quite a few add-ins for the company I'm working with. Right now, those are deployed via drag/drop. I basically send an e-mail with the update explanation, and pray that the collaborator read & install the new updated version.
However, with the collaborator population increasing, and beeing split between Europe & India, and on top of that the add-ins updates releasing at a faster rate (because of the increasing number of functionalities), I find that the drag/drop & pray method is no longer suited.
I then have to take a decision to choose a proper way of handling things. How are you managing your add-ins deployement ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
CGBenner
@AndrewHumiston Is this something you have dealt with?  Do you have any advice here?
Chris Benner
Industry Community Manager – Design & Manufacturing
AndrewHumiston
@FINET_Laurent
The add-in battle is something i have struggled with as well. i have gone as far as creating a shortcut to the folder where i want the user to add them, then when i push an update, they close the software and drag the attachment from the email (we use and admin folder in the vault) to the correct folder for the specific application.
i wish there was a way to signify the file path for add-ins or be able to add another address to the default path, so that you could use the vault to place them in the correct folder.
we use a setup like that for our symbol libraries and styles. along with our ilogic rules.
Frederick_Law
You can look into a install package, Windows program installer.
I'll think VS has something to do that.
CGBenner
@FINET_Laurent Hello, do you still need help with this question?
Chris Benner
FINET_Laurent
@CGBenner  I'm still digging the subject. Unfortunatly no proposition here will be the solution of my choice. I have some idea of what I want & how I want it and honnestly it sounds kind of sexy. I just need to implement it (throw my idea against reality to see if it passes the test).  🙂
Kind regards,
FINET L.
CGBenner
@FINET_Laurent I can't wait to hear how it goes!  Good luck!
Chris Benner
