I have reinstalled Invetor 2016 2 tiems, excel 2013 (ms office 2013) 1 time, but still I get:
Error # 429ActiveX component can't create object
in excel 2013 vba (see picture).
I also tried manually deleting windows 7 64 bit registries connected to inventor, and running in administrative mode cmd, and issuing:
cd "c:\Program Files\Autodesk\Inventor 2016\Bin\"
and
Inventor.exe /install
Everything with no success - still getting Error # 429ActiveX component can't create object in VBA of Excel 2013 (see picture).
I also installed process monitor (from sysinternals) and I am seeing following:
HKCR\Inventor.Application
Class: Registry
Operation: RegOpenKey
Result: NAME NOT FOUND
Path: HKCR\Inventor.Application
Duration: 0.0000024
What to do?? Anybody have any idea?
I tried also manually register RxInvetor.tlb with:
c:\Program Files\Autodesk\Inventor 2016\Bin\Bin32>regsvr32 RxInventor.tlb
but getting:
The module "RxInventor.tlb" may not be compatible with the version of Windows that you're running. Check if
the module is compatible with an x86 (32-bit) or x64 (64-bit) version of regsvr32.exe.
