Hey
Anyone else experiencing issues with their 3D space mouse & 2022? Up until this version, it worked perfectly and would pan around center screen / center mouse point instead of model center point but in 2022, it pans around center no matter what i do. I looked at the registry setting and its the same as the previous versions albeit, i did use the registry hack on previous versions which changed the Registry version below to 21 but when i do the same in 2022, nothing changes....
Registry
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion26.0\System\Preferences\Display]
"Viewing Command Options"=dword:00000021
Is there another way to get the 3D mouse panning correctly? it makes no sense zooming into a detail and with 1 slightest touch of the 3D mouse, i pan into space
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Solved by ChrisMitchell01. Go to Solution.
@NachitoMax
Hi, have you cheched the 3D Connexion website to see if there are newer drivers for IV 2022?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
I have not seen any difference in 2022 from previous releases.
You might try going in to Orbit with the mouse and do a longgg left click where you want the origin of Rotation/Pan and then go back to the 3D Connexion device to see if it now behaves as expected.
This info from 3Dconnexion support has been posted in a few other similar topics:
"We suggest asking customers to ensure that they have a recent driver installed (v. 10.7.2 or newer is required) and then suggest to follow up with 3Dconnexion directly for all matters concerning the add-in. Our Forum is at http://forum.3dconnexion.com/"
Hope this helps,
Chris
