Announcements
3D SKETCH
lkirit2000
3D SKETCH
lkirit2000
Hi
I have created a sketch and projected it onto another plane.
Then I changed the dimension of the original sketch. After that I observed the projected sketch didn't align with the original, why ?
I have attached a CAD file.
Kiri
Replies (12)
JDMather
@lkirit2000
I don't observe any misalignment?
Can you post image?
If you were expecting Workplane2 to move with the sketch - that doesn't make logical sense as the Workplane isn't a child of the sketch.
Not sure why you would use 3D sketching for what could be simple 2D sketches.
lkirit2000
Hi JDMather,
I make a 3D frame for FEA analysis.
Now it is aligned, but earlier it was not.
The project image is always child of parent, It means when I update the parent projected image also will change.
Am I correct ?
Kiri
JDMather
I was referring only to the Workplane, not the sketch as I didn't observe anything wrong with the sketch projection.
I don't know why a 3D sketch is needed for FEA analysis, but it is far far easier to create and edit a 3D sketch by projection from a 2D sketch.
kacper.suchomski
Hi
All updates are correct for me too.
But I don't fully understand this workflow.
2D sketches are more stable than 3D sketches. Using three 2D sketches in this case will be complete (two of which will be associative).
At this point, your sketch is unstable and can be easily moved around and therefore broken.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
lkirit2000
Hi
I need to make some clarifications,
Are 3D sketches weak compared to 2D sketches?
I am using a 3D sketch for FEA analysis.
Are you recommending a 3D sketch to use in FEA or Not?
Kiri
kacper.suchomski
3D sketches are less stable than 2D sketches and are only recommended in situations where the intended goal cannot be achieved otherwise.
Kacper Suchomski
lkirit2000
Hi
Can I use 3D sketch for FEA ?
Or  I need to go with the 2D sketch?
Kiri
kacper.suchomski
Yes, you can. It is simply not recommended to use 3D Sketches unless absolutely necessary.
Kacper Suchomski
johnsonshiue
Hi! I suspect this could be related to frame member alignment issue. The frame members are default aligned to camera angle. To ensure consistent member alignment, you will need to edit each frame member -> Align -> select a static planar reference. After that, the frame members will align to the plane when the skeletal reference is changed.
Many thanks!
Software Test Engineer
lkirit2000
Hi Team,
Please see the attached image and CAD file.
Every thing looks good, but I am able to constrain the two ends.
What went wrong ?
Kiri
JDMather
@lkirit2000
Why are you still using 3D sketch when 2D sketch is so much easier?
2D or 3D sketch has nothing at all to do with FEA.  FEA doesn't care. Irrelevant.
BTW, 3D sketch is just as robust as 2D sketch when done properly but generally harder to create and edit.  You can use 2D sketches to generate and edit the 3D sketch. Your geometry is all planar - so there is no real need for 3D sketch.
johnsonshiue
Hi Kiri,
You have found an interesting limitation. The warning message basically says that the line is connecting two 3D sketch points and one is a parent of the other. This is because the right side of the sketch geometry is projected from the left side. When you try creating a line to connect the two points, the cyclic relationship error is triggered.
To avoid the error, you may create another 3D sketch and create a new line connecting the two points. It should work.
Many thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
