Hole Pattern Perpendicular to Lofted Flange
andrewdroth
Advisor Advisor
Message 1 of 8
andrewdroth
I am struggling to come up with an elegant and efficient method for creating slotted holes perpendicular to a lofted flange in an irregular pattern layout.
I created a surface, and used workplanes to split it creating the nodes where I would like the center of my slots to lie.
I then used those nodes and the surface itself to create axes that are normal to the surface. This is the orientation I would like to cut my slots.
I thought I could use the axis and workpoint to define an iFeature, but it appears an axis isn't a viable input. Why is that?
So it looks like I will need to create 320 workplanes to compliment the axis in order to make iFeatures work.
Is there a better way to achieve this?
Is there a quick way to place multiple iFeatures once the inputs have been defined?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Replies (7)
Message 2 of 8
kyled
best way is to not. provided flat pattern with point data and standard hole detail. Why bother placing the detail!
BUT i am down for kerplunk
Message 3 of 8
andrewdroth
I need it to match another part that mates up to in in order to confirm the holes line up prior to cutting. Plus it looks better in the detail views if the fasteners don't appear to be interfering with the material.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 4 of 8
andrewdroth
I'm So close!
I can get a 3D sketch pattern to *almost* do what I need. I just need to keep the slot profile horizontal.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 5 of 8
andrewdroth
Is there a way to control the rotational alignment of a feature when using a 3D sketch driven pattern with a reference face?
I'd like to keep the slot horizontal while maintaining perpendicularity to the face.
This is related to a workflow described here.
https://forums.autodesk.com/t5/inventor-forum/hole-pattern-perpendicular-to-lofted-flange/m-p/786905...
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 6 of 8
andrewdroth
I think this is what I need.
https://forums.autodesk.com/t5/inventor-ideas/improvements-to-sketch-driven-pattern/idc-p/7284345
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 7 of 8
Xun.Zhang
Hi Andrew,
Have you tired iCopy for your case? It should be what you desired.
http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-4882DCBA-5302-4397-98CC-791BA9F1B9E2
Thanks!
Xun
Message 8 of 8
No, I'm trying to accomplish this in the part environment.
