3d model with angles
Hello guys,
I'm trying to model a Tower Tulip chair as the one I show you in the attached document. However, I'm unable to develop and place (correcty) the bars holding the legs of the chair (black thin bars).
The bar holes should be placed via a Mate axis-to-axis constraint (I guess), as they will be tight to the wooden legs by a bolt.
I'm using Inventor 2018 Professional.
Could please someone of you help me?
Replies (18)
TheCADWhisperer
Attach assembly here.
Multi-body modeling would be easiest technique.
Here you're!
Thank you!
Just for your information.
I've been trying to fix it with a 3D sketch in the assembly, using Sweep or Loft. But, I don't get elegant results.
Regards
TheCADWhisperer
An assembly must include part files (*.ipt).
I've attached the diferent together in a RAR file.
I hope it's all you might need.
Regards
TheCADWhisperer
I don't have a rar extractor - I only use built-in Windows zip.
No problem. Here's in ZIP format
TheCADWhisperer
Missing part files.
Also, Holes in bottom of seat are incorrect size.  There will not by any material for the M6 threads.
I think this time I've included all the files needed.
I use Tornillo_Silla_Tulip as the fasteners to hold the legs and chair seat together.
Regards
TheCADWhisperer
Try again.
What do I have to try?
johnsonshiue
Hi! The following two parts are still missing. Please attach them here.
Tema_3_Pata_Silla:1
Tema_4_Soporte_Sujecion_Pata_Asiento-Silla:1
Many thanks!
Software Test Engineer
Here you're.
Thank you!
TheCADWhisperer
I can't find these files?
Thank you guys.
I'm attaching a new version of the assembly in which I've partially solved the bars problem, (though still needing some improvements).
I hope this time I include of the files needed.
Regards
Thank you Johnson.
I'm attaching a new version of the assembly in which I've partially solved the bars problem, (though still needing some improvements) + the files requested.
Regards
WHolzwarth
Pata1_Pletina1.ipt is still missing.
A first issue needing a change is the leg's angle versus the floor. I'd suggest 0 deg instead of 10 deg.
Walter Holzwarth
Thank you Walter.
Here's the missing part.
Regards
