3D Equation Curve Help
JDMather
Consultant Consultant
Message 1 of 8
JDMather
I am trying to enter these equations into a 3D sketch equation curve.
How do I get theta as a function of t?
Replies (7)
Message 2 of 8
Justin.B.
You can just sub the value you want for theta right into the cos function's brackets.
x(t) = R * cos( r/R * sin(t) )
y(t) = r * cos(t)
z(t) = R * sin( r/R * sin(t) )
Note your screenshot shows z(t) using cos(), but in your blue comment it's sin(). I don't get a particularly shapely result from either, but I am able to generate the equation curves entering it this way.
Message 3 of 8
JDMather
@Justin.B. wrote:
...Note your screenshot shows z(t) using cos(), but in your blue comment it's sin().
Oops, thanks for catching that.
That sort of simple mistake can be hard to spot without someone else reviewing the work - we miss our own mistakes.
Let me experiment some more...
Message 4 of 8
I believe theta needs to be an angular unit... and add a converter at the end of your formula like so...
 r / R * cos(( d0 - d1) * 1 deg) * 1 deg
Message 5 of 8
Justin.B.
Bravo if you can define the equations, but you might also have an easier time just letting Inventor wrap the circles around circles for you.
Message 6 of 8
JDMather
Well, at least I see that success should be within reach...
Oh wait a minute, you used geometry rather than Equation Curve...
Message 7 of 8
Justin.B.
If you insist.
Message 8 of 8
johnsonshiue
Hi JD,
I took a quick look. Would Cylindrical coordinate system or Spherical coordinate system work better for this case?
Many thanks!
Software Test Engineer
