GT&D Annotation, Thread
DanfysikClaus
DanfysikClaus
Hi
I like to put a GT&D tolerance on a metric threaded hole.
I can do so BUT only with the drilled hole dimmension, NOT the Thread.
Oppersite, when I use the Hole/Thread feature the hole is display BUT not the geometric tolerances (GT&D).
How do I but the GT&D on the Annotation(Hole/Thread) feature OR how do I but the Metric/pitch symbol on the Annotation (Tolerance feature) ?
I'm aware that thread on the feature hole is cosmetic.
Any suggestions or comments will be appreciated  😉
Claus
DanfysikClaus
I found a work-around.
The problem occurs when creating e.g. a tapped hole with a counterbore feature.
The solutions is first to make the tapped hole with no extra feature, then make the 3D annotation and finally change the tapped hole to a counterbored tapped hole !
Maybe this detail will be fixed in 2025 or later ?
