09:09 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to design two clamp blocks (top and bottom) that have a gripping cavity that matches a imported step file of a tube. I have used "combine" before to cut a surface contour for a tube that only changed direction in 2 axis. I dont know where to start when you have a tube that changes in all 3 axis. I need the clamps contour to match the split line of the tube so that the tube can be inserted into the clamps. I attached a example iam file for what Im trying to do.
Link copied
