2D Drawing some components being shown with dashed line/ wireframe when they shouldnt
jelle_nobus
jelle_nobus
Recently encountered an issue where some components are shown as wireframe/ dashed line even tough they shouldnt be. components are shown as purchased in BOM.
See image attached below.
Is there anyone who knows why this occurs and how to fix it?
jelle_nobus
Nevermind, i found the issue... problem already solved.
CGBenner
@jelle_nobus
Hi, would you mind sharing what it was that you found, in case others have the same issue later?  Thank you in advance.  🙂
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
jelle_nobus
Sure, here's the situation i had explained (with some relevant background):
These bolts are placed in the assembly as a assembly, which is patterned. (so bolt, nut and rings are placed inside their own assembly). However i don't want the assembly of bolts to show in the BOM, i want the parts inside the assembly to show. i had made the bolt assembly a reference (in model tree, right click>BOM Structure>reference). When editing the 2D drawing i saw some parts were not showing in the list, so then i realized i had set that bolt assembly to the wrong BOM structure. i set them to normal again, opened the BOM in the assembly and changed the assembly to "phantom" which resolved the issue i had in the 2D view and made the missing items appear on the parts list.
CGBenner
@jelle_nobus Thank you for taking the time to share that.... hopefully it will be helpful to others who run into similar problems!
Chris Benner
