2026 - Drawing - Missing Components
NachoShaw
Advisor Advisor
NachoShaw
Hi
I have noticed in 2026 the issue of missing components within a drawing view. Here are 2 images: the left is the drawing sheet with missing items, on the right is the view taken from the drawing sheet in the drawing view edit mode clearly showing the components
Graphics are up to date
this didnt happen in 2024
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
mluterman
Usually when I encounter something like this, I try the following:
1. Update my video driver (if it isn't).
2. Try rebuilding the model and its components.
3. Toggle the drawing view to raster and back.
4. Try the other display options in \Tools\Application Options
5. Cry.
johnsonshiue
Hi Nacho,
This could also be bad bodies related. Open the assembly -> press Ctrl+F7 (make sure C:\Temp exists). Is there a bad body reported?
Please share the files with me directly at johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
NachoShaw
Hey Johnson
Thanks for replying. Unfortunately i wont be a AU this year to keep the Inventor cause going :), next year
There wasnt a bad body report but there was a debug.txt file.
Nacho
johnsonshiue
Hi Nacho,
Then I do need to see the files. Please share them in zip with me directly at johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
