Message 1 of 32
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When using the Make Components : Selection dialog in 2022.2 the "Next>>" button is grayed out when attempting to place another solid into an existing target assembly. This process has worked until Inventor 2022.2. Is there another process to replace this functionality? A work around is to uncheck “Insert components in target assembly” but then the individual parts have to be placed into the target assembly manually.
This doesn’t seem to be a problem if the target assembly does not already exist.
Thank you
David
Inventor Professional 2026.1
Windows 10 Pro 64 bit
