2021 Installation
2021 Installation
V-Draft
Message 1 of 14
2021 Installation
V-Draft
I want to install 2021 version, but in my products it shows version from 2022 - 2025. What i have to do, to install the 2021 inventor version
Replies (13)
Message 2 of 14
James_Willo
Hi Vaughn, is there a specific reason why you need the 2021 release?
We don't support this anymore which means we won't fix anymore bugs or security issues that may arise.
James W
Inventor UX Designer
Message 3 of 14
johnsonshiue
Hi! Please log on to manage.autodesk.com and click on "Ask the Assistant." It is a bit tedious but eventually you will get a link to download Inventor Pro 2021.
Many thanks!
Software Test Engineer
Message 4 of 14
V-Draft
Thanks For your precious time. I tried but I am not able to download.
Message 5 of 14
V-Draft
Hello sir, Thanks for your precious time. I tried but I am not able to download the 2021 version.
Message 6 of 14
SBix26
When you start the Ask the Assistant, select as follows:
Hope this helps.
Sam B
Inventor Pro 2025 | Windows 11 Home 23H2
Message 7 of 14
V-Draft
Hi James,
Thanks for your precious time. I will try as you said.
Message 8 of 14
david_abiyo
Hi, I've tried downloading inventor 2021 this way, and am able to get the assistant to give me the download link. When I click on it however, nothing happens. Is the link broken or is there another solution to this?
Message 9 of 14
SBix26
The link is attempting to open Autodesk Download Manager-- is it installed on your system?  Or is there a window that needs permission in order to install it?
Sam B
Inventor Pro 2025.0.1 | Windows 11 Home 23H2
Message 10 of 14
landoncharris1
Community Visitor
Community Visitor
I'm having the same issue, but it gets stuck once you start the download if you download in parts for multiple computers or pops up an "Access is denied" error if you do it for yourself.
Message 11 of 14
fzan7957
Community Visitor
Community Visitor
Message 12 of 14
SBix26
Autodesk only supports the current version (2025) and the three prior versions.  I tried using the Autodesk Assistant, though, and told it that I wanted to download Inventor 2021, which it provided:
Sam B
Inventor Pro 2025.2.1 | Windows 11 Home 24H2
Message 13 of 14
Florian_PustWBNDJ
Community Visitor
Community Visitor
I did that but have trouble installing. as soon as i give permission to install an error pops up: "unable to install: An error occured while preparing for the installation."
vers 2021. i already uninstalled every other autodesk product on my laptop.
Message 14 of 14
SBix26
Someone here may know the answer, but the Installation & Licensing Forum is the best place for installation issues, I believe.  Good luck!!
Sam B
