2019 Ribbon Appearance Issue
BeKirra
Advisor Advisor
Message 1 of 12
BeKirra
The company IT has recently installed 2019 version with updates to all our machines.
Here is the info:
Build 330, Release: 2019.4 Date: Mon 04/01/2019
Unlike older version that I currently use, the ribbon settings seem not working properly.
It doesn't make any changes when I select "Normal", "Text Off", "Small", "Compact" or "Large" in Ribbon Appearance.
Do you have similar experience? How to fix it?
BTW my colleage's 2019 is working fine with the update to "Build 278, Release: 2019.3" which is older than mine.
Thanks in Advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Replies (11)
Message 2 of 12
SBix26
Post a screen shot of your ribbon.
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
Message 3 of 12
johnsonshiue
Hi! It does not sound right to me. Have you tried using Inventor Reset Utilities (All Programs -> Autodesk -> Inventor 2019 -> Tools) to reset the default settings?
Many thanks!
Software Test Engineer
Message 4 of 12
BeKirra
@johnsonshiue
"Hi! It does not sound right to me. Have you tried using Inventor Reset Utilities (All Programs -> Autodesk -> Inventor 2019 -> Tools) to reset the default settings?"
Sorry, I don't find the path that you mentioned above.
@SBix26
X² + Y² = C²
Message 5 of 12
SBix26
At the right end of the tab titles (the dark gray space above the tool icons) there is a tiny up arrow button with an even smaller drop-down arrow next to it-- click on the drop-down arrow and find the menu shown below; I believe that you have accidentally chosen Minimize to Panel Buttons.  Choose Cycle through All, then click the up arrow button to cycle back to the normal appearance.
Sam B
LinkedIn
Message 6 of 12
BeKirra
Sorry, what I have already had is exactly the same as your screenshot.
X² + Y² = C²
Message 7 of 12
SBix26
Click the up arrow to cycle through the choices back to the default ribbon (three clicks should do it).
Sam B
LinkedIn
Message 8 of 12
JDMather
Message 9 of 12
BeKirra
Thanks @JDMather for your help.
It is too simple. 👍
And thanks to@SBix26 too.
BTW I notcie you probably attached a photo but I don't see it. I guess that your comment is the same as @JDMather .
X² + Y² = C²
Message 10 of 12
damacylo
Goog, solve my problem
Daniel Avila
Hydraulic Eng.
Message 11 of 12
tomasz.sztejka
Amazing! How were You able to figure it out?! I couldn't see any connection between "cycling through minimalizations" and "not minimizing at all".
Message 12 of 12
SBix26
Experience, though that was far enough in the past that I might not have figured it out today.
Sam B
Inventor Pro 2023 | Windows 10 Home 21H2
