2019 Hole Tool - Feature direction is not intelligent (always wrong direction)
- Mute
- Permalink
- Report
When the 2019 hole tool was release I was pretty excited about it, but the more I use it, the more I want the old one back...
It seems like for my workflow (a lot of as-built parts) that the new hole tool could use some tweaking. A lot of the time I use a shared sketch for parts meaning that I am given a sketch for a part and have to turn it into a model. Since I have all the details already, it doesn't make sense to create multiple sketches for difference feature types.
When using the hole tool from a shared sketch, the implied direction for which direction the hole should go seems to have zero intelligence built into it to guess the correct direction. I've had this on many occasions, but I guess the Tuesday after a long weekend and my first job of the day I'm not in much mood for this kind of thing so I'm finally bringing it up instead of just dealing with it.
This morning I created a very simple sheet metal bracket 5/8x9.5x30. It has 6 holes in it of various sizes and I created the profile for the part as well as the hole locations all on one sketch. When I go to put in the hole features for the plate, the hole direction seems to automatically assume that my holes are going in the -Z direction even through the default direction for my sheetmetal face was in the +Z direction, therefore my holes won't work unless I change the direction. Not a huge deal, but why can't the hole feature analyze which direction it should probably go and adjust the hole tool window?
I guess the TLDR, the "Default" setting for the hole tool have zero intelligence built into it.
