- Mute
- Permalink
- Report
I am having a very annoying graphics issue in Inventor 2019. I am new at the company and I am using a brand new work station so I don't think it as an update issue. It has been happening since I started as well.
My issue is that sometimes when I flip between inventor tabs, about an inch and a half of the bottom and right hand side of my window will not switch tabs, and will show the previous tab still. I can usually fix it by relaunching Inventor. But sometimes it only fixes it for a couple minutes, and sometimes it doesn't fix it at all. I thought it may be a graphics card issue?
But I looked into it, and my graphic card is over the minimum requirements and just under the recommended, and I looked at the performance tab on task manager and my GPU doesn't seem to be causing a bottleneck. Does anyone have any idea what is going on here? I have attached a photo for reference. I cant attach a model because it happens with every model, so the issue is not with the files.
