2017 Thicken/Offset Join unexpected behavior, Intersect, New Solid
annette.jennings42
annette.jennings42
I work on imported solids (I first use shrinkwrap substitute creating separate bodies) and then use the thicken/offset tool to exaggerate the few otherwise tiny features to a 3D-printable size. I often exceed 1000 thickens in a file. Twice now upon resuming work after closing a file for the day, Thicken/Offset behaves unexpectedly.
Where the "Join" button in the Thicken/Offset dialogue normally works just fine to thicken a solid, when it bugs, it erases the object and an arbitrary portion of adjacent features. It seems to be behaving like Intersect but in a very narrow window/box in close proximity around the feature.
NOTE I have a work-around - using the "New Solid" button will successfully thicken the feature in question.
But this is not optimal as I often need to thicken in multiple axes and so having multiple bodies increases the number of steps in the workflow
Is there a known issue with Thicken/Offset JOIN sometimes cutting away portions of a model?
johnsonshiue
Hi Annette,
The behavior does not sound right to me. Could you share a simple example here? I would like to understand the behavior better. When you try thickening, did you uncheck "Auto-blending" option?
Many thanks!
Software Test Engineer
annette.jennings42
Please reference the images attached for an example of disappearing or cut/trimmed geometry.
Yes, auto-blending is turned off.
johnsonshiue
Hi! Purely based on the images, it looks like a geometry specific behavior. Could you attach the part here or send it to me directly (johnson.shiue@autodesk,com)? I would like to understand the behavior better.
Many thanks!
annette.jennings42
I cannot duplicate the problem today. I completed all the modifications yesterday using the "new solid" work-around mentioned in the OP.
If this problem comes up with another file, I will email you.
