Announcements
2014 Animate ipn
2014 Animate ipn
I'm setting the camera views between sequences and would like to pause a few seconds between when the sequence finishes and before it switches to the next camera view.
Is this possible without some trickery?
Does anyone know of some trickery?
Do later versions allow this level of editing?
J.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I'm assuming you are in the Presentation Environment, what version of Inventor are you using?
There have been a few changes over the years that might affect how to go about doing this.
If you are in 2018 you need to drag the Storyboards Panel top line to expand the view and you can drag the tweaks around to whatever time you prefer.
Please select the Accept as Solution button if a post solves your issue or answers your question
JDMather
Smiley Wink
kelly.young
Autodesk Support
Autodesk Support
You know I'm challenged with finding the right release version @JDMather Smiley Wink
@Anonymous I think you can insert an arbitrary simple part, animate a tweak, then add it to the sequence, set it to be not visible so it is animating yet not visible? I tested it and think it works.
Please select the Accept as Solution button if a post solves your issue or answers your question.
I've viewed the newer version animations, they appear more user friendly with more controllability, always a win/win when that happens. Thanks.
J.
JDMather
@Anonymous wrote:
... newer version animations, they appear more user friendly
For older version ipn - see attached pdf pgs 29-32
