15% CPU usage at idle Inventor 2018
COLINBRUSCHI
Message 1 of 10
COLINBRUSCHI
Hi All,
Inventor 2018.1.2
With any IPT, IAM or IDW open I'm getting a constant 15% CPU usage from Inventor, this usage drops off once the file is closed while still having Inventor open. Any ideas?
Replies (9)
Message 2 of 10
mcgyvr
Have you restarted your computer and see if that stops?
Running any non-default addins?
Message 3 of 10
COLINBRUSCHI
Yup, numerous boots have been done since I noticed this. I've tried disabling all add-ins thru the add in manager, then restarting inventor with non of them running, still getting this CPU usage at idle. Other users here don't seem to have this issue.
Message 4 of 10
Mark.Lancaster
@COLINBRUSCHI
Are your files stored locally or on the network?
Here's a few things you can try..
1.  Disable your anti-virus application and try again.
2.  Are you using a VoIP phone in your office?  If yes is your machine connected directly to the phone or the jack on the wall?
3.  If all of your files are locally, disconnect from your network and launch Inventor again and test.
Mark Lancaster
Message 5 of 10
dgorsman
Is it the actual Inventor EXE?  Or is it a Chromium Host executable?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 6 of 10
COLINBRUSCHI
@Mark.Lancaster
We use vault but files are local when working with them.
Yes we use voip phone system thru network, but disabling the phone app and disabling the LAN connection & restarting Inventor shows no difference.
I cant disable anti virus since its admin managed but everyone uses the same program and no issues.
@dgorsman
Message 7 of 10
johnsonshiue
Hi Colin,
If possible, could you share your machine spec? Start up Inventor and open a part. Go to Tools -> Application Options -> Hardware -> Diagnostics -> copy and paste to a text file.
Many thanks!
Software Test Engineer
Message 8 of 10
COLINBRUSCHI
@ Johnson Shiue (johnson.shiue@autodesk.com)
Sorry for the delayed response.
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA GeForce GTX 750 Ti
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 5_0
Performance Mode
Hardware Renderer
OGSScene.dll
Graphics driver file C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll is version 22.21.13.8494
The display is using 32-bit color
Inventor Version:
Build: 171, Release: 2018.1.2 - Date: Thu 08/24/2017
64-Bit Edition - 131072.00 GB
System Information:
Operating System: 64-bit Microsoft Windows 10 Pro (Build 9200)
Language: English
System Manufacturer:
System Model:
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (1 processor, 4 physical cores, 8 logical cores)
System Memory: 31.983 GB RAM
Graphics Device Information:
Renderer: HAL
Manufacturer: NVIDIA
Chip Type: GeForce GTX 750 Ti
DAC Type: Integrated RAMDAC
Graphics HW Memory: 1.970 GB
Display Mode: 1920 x 1080 (32 bit) (60 Hz)
Graphics driver file: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_24ddebfb518b5a55\nvldumd.dll
Driver file version: 22.21.13.8494
Driver Date: 18 July 2017 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: NVIDIA GeForce GTX 750 Ti
Vendor ID string: 0x000010de
Device ID string: 0x00001380
VendorID: 10de
DeviceID: 1380
SubSystemID: 31021462
Revision: a2
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 1.970 GB
Dedicated System Memory: 0 MB
Shared System Memory: 15.991 GB
DxDiag System Information:
Operating System: Windows 10 Pro 64-bit (6.2, Build 9200) (14393.rs1_release_inmarket.161102-0100)
Language: English (Regional Setting: English)
System Model:
Processor: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
System Memory: 32768MB RAM
Page File: 8614MB used, 25136MB available
DirectX Version: DirectX 12
DxDiag Version: 6.02.14393.0000
DxDiag Graphics Device Information:
DirectX Version: 12.0
DDI Version: 12
DDI Version Number: c
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Revision: Unknown
Graphics HW Memory: 18392 MB
Display Mode: 1920 x 1080 (32 bit) (60Hz)
Driver file version: 22.21.0013.8494
Driver Date: 18/07/2017 02:00:00
WHQL Level: 1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
Message 9 of 10
johnsonshiue
Hi! Many thanks for sharing the hardware profile! It looks very nice. I don't see anything wrong with it. It is actually better than my desktop machine. If you close Inventor and restart it, does it still stay at 15%?
Thanks again!
Message 10 of 10
COLINBRUSCHI
Yes I have restarted numerous times.
