0's in chain dimension
Message 1 of 12
No clue from where the zero's come?
Replies (11)
Message 2 of 12
mdavis22569
Can you share an example ...
otherwise, it'll just be guesses ....
Mike Davis
Message 3 of 12
Cadmanto
Like Mike, just guessing without the file to look at, but my best guess is it appears to be a "0" dimension because it looks as though there are leader extensions on either side of the "0".  I will bet that you can drag the dimension. and relocated the extensions
I also think it was a dimension that came from the center of the protrusion to maybe an edge and because all of them are the same, a reference point was lost and it defaulted back to the center.  Thus the "0".
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 12
Here is the drawing
Message 5 of 12
mdavis22569
It looks like they recreated it each time on it ...
I'm missing the IPT ..but looking at the file, you have a chain for all of the 481 / 360 / 360
then they came in and put a zero dim in manually.
Screencast will be displayed here after you click Post.
a630607f-96f7-4aca-abaa-1ac47ab08234
Mike Davis
Message 6 of 12
Cadmanto
Looking at the drawing, my assumption was right.  Just a dimension that can be deleted.
Not sure how it got there or how it was created, but I go back to my original point about it being a dimension that came from a different lost reference point.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 7 of 12
mdavis22569
@Anonymous
Did my screencast show up?
Mike Davis
Message 8 of 12
no
Message 9 of 12
mdavis22569
sorry ...
What's I'm showing:
It was supposed to be this:
Mike Davis
Message 10 of 12
mdavis22569
sorry ...
What's I'm showing:
Mike Davis
Message 11 of 12
I also met this issue and during tests and trials we notice that when you Right Hand Click > Continue and hover on FIRST placed point then the dimension change into proper one.CHAIN.png
Message 12 of 12
...more then, it seams that it is a FEATURE not bug. It switch between vertical(horizontal) or Aligned placement.CHAIN2.png
