Inventor : Activation de cartouche a haut a droite avec i-logic
denis.semeniuc
384 Visites
6 Réponses
Message 1 sur 7
denis.semeniuc
Bonjour,
Comment activer le cartouche a haut a gauche de la page.
je utilise ca :
ActiveSheet.ChangeSize("B", moveBorderItems := True)
ThisApplication.ActiveDocument.ActiveSheet.Orientation  = kLandscapePageOrientation
ActiveSheet.Border = "Cadre large(PE)"
	ActiveSheet.SetTitleBlock("MPE")
Merci de votre aide
Le titre du sujet a été modifié par un modérateur pour faciliter la recherche. Titre original:
0 J'aime
Solutions acceptées (3)
385 Visites
6 Réponses
Message 2 sur 7
A.Acheson
Solution acceptée
Hi @denis.semeniuc
The titleblock location is only available using the Inventor API. See LocationEnum here
To use the locationenum you need to get the location property of the titleblock
Syntax
TitleBlock.Location() As TitleBlockLocationEnum
To use the titleblock you can add this from the sheet using add titleblock where you can set location, definition and prompted entry in one go.
Syntax
Sheet.AddTitleBlockTitleBlockDefinition As Variant, [TitleBlockLocation] As Variant, [PromptStrings] As Variant ) As TitleBlock
Regards
Alan
0 J'aime
Message 3 sur 7
FINET_Laurent
Solution acceptée
Hello @denis.semeniuc,
You can use The folowing code to plate a titleblock in the desired location. The sheet must not contain existing titlelbocks & don't forget to update the name of the titleblock accordingly :
Dim titleblockName As String = "ISO"
Dim doc As Inventor.DrawingDocument =   ThisApplication.ActiveDocument
Dim s As Inventor.Sheet = doc.ActiveSheet
Dim def As Inventor.TitleBlockDefinition = doc.TitleBlockDefinitions.Item(titleblockName)
's.AddTitleBlock(def, TitleBlockLocationEnum.kBottomRightPosition)
's.AddTitleBlock(def, TitleBlockLocationEnum.kBottomLeftPosition)
s.AddTitleBlock(def, TitleBlockLocationEnum.kTopRightPosition)
's.AddTitleBlock(def, TitleBlockLocationEnum.kTopLeftPosition)
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
0 J'aime
Message 4 sur 7
denis.semeniuc
Merci pour le code.
il y a une erreur :
je bien mis le nom du cartouche
0 J'aime
Message 5 sur 7
denis.semeniuc
Désolé, je trouver l'erreur.
le TitleBlock été avec entrance(il faut écrire les donne) c'et ne marche pas avec cette fonction.
Il y a la possibilité applique la même chose pour cartouche avec Entrance?
0 J'aime
Message 6 sur 7
FINET_Laurent
Solution acceptée
@denis.semeniuc
Yes you can, but you need to create an array that contains the value for all prompt entries. Here an example with a title block that has two prompt entries :
Dim titleblockName As String = "TEST"
Dim data As String() = {"Value1", "Value2"}
's.AddTitleBlock(def, TitleBlockLocationEnum.kBottomRightPosition, data)
's.AddTitleBlock(def, TitleBlockLocationEnum.kBottomLeftPosition, data)
s.AddTitleBlock(def, TitleBlockLocationEnum.kTopRightPosition, data)
's.AddTitleBlock(def, TitleBlockLocationEnum.kTopLeftPosition, data)
Kind regards,
FINET L.
0 J'aime
Message 7 sur 7
denis.semeniuc
Merci, ca Marche très bien.
0 J'aime
