Compléments Inventor
Non applicable
733 Visites
5 Réponses
Message 1 sur 6
Non applicable
Bonjour,
Depuis ce matin lors de l'ouverture d'Inventor aucun compléments ne sont chargé. Je suis allé dans le gestionnaire de compléments et j'ai tout mis à charger au démarrage.
Tout a l'air OK sauf que je n'ai pas les commande connexion et deconexion du coffre fort Vault.
Est-ce qu'il existe pour la version 2012 un outil qui réenregistre tous les compléments inventor comme le faisait l'outils Inventor_modules_reregistration.cmd.
Merci pour votre aide.
Salutations
Dom
Since this morning at the opening of Inventor are no additional charge. I went to the manager of any supplements and I began to load at startup.
Everything seems OK except I do not have the connection and control of safe deconexion Vault.
Is there a 2012 version for the tool to re-register all supplements as did the inventor Inventor_modules_reregistration.cmd tools.
Thank you for your help.
greetings
Dom
0 J'aime
Solutions acceptées (2)
734 Visites
5 Réponses
Message 2 sur 6
karthur1
So are you saying that in Inventor, you do not have a vault menu?  1. Make sure you are in a "Vault" enabled project. 2.  Make sure the vault add-in is loaded (Tools>Add-ins).  You should see Inventor Vault there on the right side.
0 J'aime
Message 3 sur 6
Non applicable
Thank's for your answer.
All is ok with all add in. With the right project and all. All is ok but only 2 command are missing. Connexion and deconnexion are missing. See atteched image.
With all other application all is good. (Mechanical, Office)
Regards
Dom
0 J'aime
Message 4 sur 6
alessandro.gasso
Solution acceptée
Please, open the addin list in Inventor, right-click, Shows Hidden Members and check if the EDM Addin is loaded.
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
0 J'aime
Message 5 sur 6
Non applicable
Solution acceptée
Yes,
Thank you.
Your answer come at the right time, i'm just creating a support case. lol.
It's mean that these errors come after the installation of the Vault SP1.
Regards
Dominique
0 J'aime
Message 6 sur 6
alessandro.gasso
Not to my knowledge.
Alessandro
Alessandro Gasso
Autodesk, Inc.
0 J'aime
