Adding some to what Jon said, both ETO Server 2016 and later, as well as C360, support Three.JS and HTML5 based client graphics.
We would welcome you to use our open source AngularJS (HTML5 and Javascript based) libraries for C360 to create single page applications (SPA's) that you can use to replace the Silverlight approach to web UI's. We use a slightly modified version internally for ETO Server projects (i.e. not open sourced) - but the overall result is the same.
We have included sample apps for our Angular libraries for C360. You can get to the sample apps at:
You can get to the javascript libaries at:
FWIW: Developing with HTML5 is a joy compared to with Silverlight. The debugging cycle is shortened considerably since Javascript and HTML (i.e. UI) changes are immediately available in the browser after you save the changes. So nice!
George Williams
D3 Technologies - Automation Solutions
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
