converting Number Value to string
What's the easiest rule/function for converting the value from a number rule to a string?
For example, I have...
Rule DoorWidth As Number = 21
What I would like end up with is an additional rule like this, based off of the DoorWidth value:
Rule DoorWidthString As String = "21"
I'm just trying to convert a numerical value, evaluated from a rule, to a string.  I know this can be done with :Name rules, by using the MakeString function, but I'm not sure how to change the value of a numerical rule to a string.
I imagine I'm missing something obvious.
Thanks!
Joe
Nevermind,
It looks like the "StringValue" function is what I was looking for.
Well, now I know 🙂
rsimington
You can also use format(%d,expression) or format(%g,expression). %d will round a number to an integer, whereas %g will keep it a decimal.
Thanks, that could be handy as well!
ebachrach
Be aware that stringvalue is not intended to reliably format the output.
For that you use the format function which uses C like notation, such as
Intent >format("my number is %g",2.301)
--> "my number is 2.301"
Intent >format("my number is %3.2g",2.301)
--> "my number is 2.3"
Elly Bachrach
Manager
Manufacturing Consulting Services - ETO
Direct      +1 (847) 676-2880
elly.bachrach@autodesk.com
Elly Bachrach
ETO/CTO Solutions Designer
Intelligent Configuration Solutions
Mobile +1 (773) 401-6980
elly.bachrach@gmail.com
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
