Show hidden lines
Show hidden lines
Lesoux
Show hidden lines
Lesoux
Hi, everyone.
Suppose you have an assembly drawing. Your drawing view contains all patrs and subassemblies that shown without any hidden lines. You want to show hidden lines for some particular parts or subassemblies, not everywhere. Inventor has option for that. You need to find a part in the Inventor tree, right-click and select option Hidden Lines.
Is there some way to do the same thing using API?
As I know, right now we can show/hide all hidden lines only.
Thanks in advance.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
AlexKorzun
There is no direct API to deal with the occurrence view style inside of the drawing view. This will appear in future version of Inventor.
As a workaround you may consider the manipulations with the browser nodes (please note: will not work in Inventor Server/C360).
Below is the browser view of the occurrence you want to toggle:
You will need to explode the hierarchy (something that will require experimentation) and execute the command in the way similar to:
Method SwitchHiddenLinesCmd() As String
    Dim fPath As String
    Try
        InventorApplication.SilentOperation = True
        Dim oDoc = GetHostObject(mySupportDrawing)
        Dim oSheet = GetHostObject(mySupportDrawing.myassemblySheet)
        Dim oView = GetHostObject(mySupportDrawing.myassemblySheet.MyAssemblyBaseView)
        Dim oTop = oDoc.BrowserPanes.get_Item("DlHierarchy").TopNode
        ' Find a BrowserNode relates with a component
        Dim oComp = oTop.BrowserNodes.get_Item("Assembly:1")
        oComp.Expanded=True
        oComp = oComp.BrowserNodes.get_Item("SUPPORT ASSEMBLY:Assembly4.iam")
        oComp.Expanded=True
        oComp = oComp.BrowserNodes.get_Item("Assembly4.iam")
        oComp.Expanded=True
        oComp = oComp.BrowserNodes.get_Item("supportAssembly")
        oComp.Expanded=True
        oComp = oComp.BrowserNodes.get_Item("LegRight")
        oComp.Expanded=True
        fPath = oComp.FullPath
        oComp.DoSelect()
        ' Switch the Hidden Lines toggle
        Dim oCommand = InventorApplication.CommandManager.ControlDefinitions.get_Item("DrawingBodyHiddenLinesCtxCmd")
        oCommand.Execute()
    Finally
        InventorApplication.SilentOperation = False
    End Try
    Return fPath
End Method
Result:
Running the code again will toggle the "Hidden Lines" back to original state
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
Lesoux
Thank you Alex for your help. Let me try this way, I'll let you know about results.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Lesoux
Well. Everything works perfect. Thanks. I just modify method as I need.
Method SwitchHiddenLinesCmd(view As Part, objList As List) As Boolean
   Try
      Dim oDoc As Any = GetHostObject(Me.Parent)
      Dim oSheet As Any = GetHostObject(Me)
      Dim oView = GetHostObject(view)
      Dim oOcc As Any = GetHostObject(view.Model)
      Dim oComp = oTop.BrowserNodes.get_Item(oSheet.Name)
      oComp.Expanded = True
      oComp = oComp.BrowserNodes.get_Item(view.displayName + ":" + oOcc.Definition.Document.DisplayName)
      oComp = oComp.BrowserNodes.get_Item(oOcc.Definition.Document.DisplayName)
      For i = 1 To length(objList)
            Dim obj As Part = nth(i, objList)
            Dim oNode As Any = oComp.BrowserNodes.get_Item(GetHostObject(obj).Name)
            oNode.DoSelect()
            oCommand.Execute()
      Next
   Finally
   End Try
   Return True
End Method
I know it will work with first level assembly only, but it's enough for right now.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
chrisdrogers
It has been 5 years since this post.  Is there a method to do this through the API or are we still required to use the browser selections and call a command?
ruthsteed
Unfortunately, the workaround provided by Alex is still the way to do this.  Providing this functionality is on our radar, but it's hard to say when it might be available.
Ruth Steed
Inventor Development
Ruth Steed
Inventor Development Team
Autodesk, Inc.
