In the Styles Editor, Feature Control Frame, Options, there is an option that allows you to merge the True Position Symbol. This is an option that should not appear in the Styles Editor as it is not stylistic. Although it is a nuance, whether the True Position box is combined (Composite) or seperate (Single Segment) carry two different meanings. While I do have the ability to change to one or the other, it is only a function that I can use if I don't need both representations on the same print. This option should be embedded within the Feature Contor Frame Command when the symbols are placed.
