VBA script: List first level sub components from assembly
pball
Mentor Mentor
Message 1 of 8
pball
Currently I have some code which loops through all sub components of an assembly and sub assemblies. However I only need sub components inside the top level assembly and not any sub-assemblies. Is there an easy way to acomplish this?
This code will list all sub components inside an assembly when a drawing is open.
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oRefDocs As DocumentsEnumerator
    Set oRefDocs = oDocument.AllReferencedDocuments
    Dim oRefDoc As Document
    For Each oRefDoc In oRefDocs
        debug.print oRefDoc.FullDocumentName
    Next
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
Replies (7)
Message 2 of 8
pball
Sorry for bumping this but I'm still trying to figure this one out.
Also perhaps something to clarify what I mean. Lets say I have the main assembly Thing.iam, I'd like to be able to get part1, assembly1, and part4. Not anything beyond the parts/assemblies in Thing.iam.
Thing.iam
-Part1.ipt
-Assembly1.iam
--Part2.ipt
--Part3.ipt
-Part4.ipt
Message 3 of 8
skyngu
what do you want first level? the name or part itself?some information are in the first level BOM or partslist.
Autodesk Inventor Professional 2027
Message 4 of 8
skyngu
try this
  Set oRefDocs = oDocument.ReferencedDocuments
Message 5 of 8
pball
That only returns the assembly included in the drawing.
I'd like the FullDocumentName for all the parts and sub-assemblies contained within the assembly placed in a drawing, but not any parts or assemblies deeper than that first level.
Message 6 of 8
Mike.Wohletz
The below is in VB.NET but you should be able to see how it was done and add make it work in VBA.
    If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
            ListBox1.Items.Clear()
            Dim oDrawing As DrawingDocument = ThisApplication.ActiveDocument
            'we will go after the first view that is an assembly
            For Each oView As DrawingView In oDrawing.ActiveSheet.DrawingViews
                If oView.ReferencedDocumentDescriptor.ReferencedDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                    Dim oAssembly As AssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
                    For Each oDoc As Inventor.Document In oAssembly.ReferencedDocuments
                        ListBox1.Items.Add(oDoc.FullDocumentName)
                    Next
                    Exit For ' we only want to do this for the first assembly found.
            Next
Message 7 of 8
skyngu
well, oDocument means "assembly document" in the drawing in this case.
I assume that there is only one assembly in the drawing. after you can get assembly from drawing, you can get first level by referenceddocuments.
you may get fulldocumentname from firstlevelonly bom or partslist too.
Message 8 of 8
pball
Thank you, it took a bit of playing around but I got exactly what I wanted.
    Dim oRefDoc As Inventor.Document
    If oDocument.ReferencedDocuments.Item(1).DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Set oAssembly = oDocument.ReferencedDocuments.Item(1)
        For Each oRefDoc In oAssembly.ReferencedDocuments
            'add to list here oRefDoc.FullDocumentName
        Next
    ElseIf oDocument.ReferencedDocuments.Item(1).DocumentType = DocumentTypeEnum.kPartDocumentObject Then
        Set oRefDoc = oDocument.ReferencedDocuments.Item(1)
This works nicely for me for getting either the part name or all first level components of an assembly. I needed this for a dialog which allows editing of iproperties from inside of a drawing, which saves loads of time.
