- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i am actually writing VBA Code to VB.Net and have a problem with a Point2D object.
The macro shall align text, views and titles in an idw using the first selected object.
In VBA the macro works fine. In VB.NET i get a failure with the COM Object.
Any idea?
This is the example in VBA for the X Axis:
Sub AlignX() Dim oDoc As DrawingDocument Set oDoc = ThisApplication.ActiveDocument Dim oSelect As SelectSet Set oSelect = oDoc.SelectSet Dim newPoint As Point2d Set newPoint = oSelect.Item(1).Position For Each obj In oSelect newPoint.Y = obj.Position.Y obj.Position = newPoint Next End Sub
VB.Net Code:
Sub AlignX()
Dim oDoc As DrawingDocument = InventorApp.ActiveDocument
Dim oSelect As SelectSet = oDoc.SelectSet
Dim tg As TransientGeometry = InventorApp.TransientGeometry
Dim newPointX As Point2d = Nothing
Dim obj As Object
newPointX = tg.CreatePoint2d(oSelect.Item(1).Position.X, oSelect.Item(1).Position.Y)
obj.Position = newPointX
Next
End Sub
In the For Each loop at obj.Position = newPointX .Net creates the failure.
Best Regards Martin
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
