VBA end code execution. Equivalent = (CTRL + BREAK + END)
I have a big macro running in Inventor and when an error appears I have a handler that shows a message on the screen:
Resume
errHandler:
MsgBox Err.Description
Err.Clear
ResumeerrHandler:MsgBox Err.Description
Err.Clear
The problem is that the message appears on the screen and when the user clicks OK, the application continues executing the code and it becomes a disaster.
I was wondering if there is a code equivalent to ( CTRL + BREAK + END) that can end the code execution when an error appears.
Best Regards,
Daniela Dubois
Software para Innovación Tecnológica S.A. de C.V..
Sure you can use the keyword "END" which just stops your program.
Be aware though that this is an emergency stop.  No clean up is done.
Anything your in the middle of is left hanging.
A Better approach is to:
   Stop any processes your program is doing
   Release any resources your using
   Close any files you have open.
   Unload any child forms
   Unload the main form.
~Gruff
