vb.net simple selection not working
matt_jlt
Message 1 of 9
matt_jlt
Basically i have some code that gets the parts list on a drawing sheet and if there is more than one allows you to manually select which to use.
It is a sub that calls up a selection class and defines the filter to be used. My problem is that once the selection event for multiple partlsists has been initialised i cannot select the parts lists. I'm not sure if it's the selection filter or the still selecting do events loop.
I have tried using the other doevents methods but it doesn't seem to work.
The code is below, If anyone could help it would be much appreciated. I have have left this problem unsolved for a long time and am finally getting to finish my addins.
Private Sub Total_Mass
' Define variables
Dim oDoc As Inventor.DrawingDocument
Dim oSheet As Inventor.Sheet
Dim oPListColl As Inventor.PartsLists
Dim oPList As Inventor.PartsList
Dim oPListCount As Integer
' Set references to variables
oDoc = ThisApplication.ActiveDocument
oSheet = oDoc.ActiveSheet
oPListColl = oDoc.ActiveSheet.PartsLists
' Reset Values
oPListCount = 0
oPList = Nothing
Select Case oPListColl.Count
Case 0
MsgBox("There are no parts lists on the active sheet", MsgBoxStyle.Exclamation)
Me.Close
Case 1
oPList = oDoc.ActiveSheet.PartsLists.Item(1)
GoTo PListSelected
Case Is > 1
GoTo MSelectPList
End Select
MSelectPList: ' Manual Parts List Selection Process
' Declare a variable and create a new instance of the select class.
Dim oSelect As New clsSelect
' Call the Pick method of clsSelect object and set filter to pick any parts list.
oPList = oSelect.Pick(SelectionFilterEnum.kDrawingPartsList Filter) ' **************** Not Sure if the filter is not working properly
MsgBox("Parts List Title = " & oPList.Title, MsgBoxStyle.Information)
End Sub
Public Class clsSelect
' Declare the event objects
Private WithEvents oInteraction As Inventor.InteractionEvents
Private WithEvents oSelect As Inventor.SelectEvents
' Declare a flag that's used to determine when selection stops.
Private bStillSelecting As Boolean
Public Function Pick(ByVal filter As Inventor.SelectionFilterEnum) As Object ' dont know if filter definition is correct
' Initialize flag.
bStillSelecting = True
' Create an InteractionEvents object.
oInteraction = ThisApplication.CommandManager.CreateInteractionEvents
' Define that we want select events rather than mouse events.
oInteraction.SelectionActive = True
' Set a reference to the select events.
oSelect = oInteraction.SelectEvents
' Set the filter using the value passed in.
oSelect.AddSelectionFilter(filter)
' The InteractionEvents object.
oInteraction.Start()
' Loop until a selection is made.
Do While bStillSelecting ' *********************************** It gets stuck in this loop
ThisApplication.UserInterfaceManager.DoEvents()
Loop
' Get the selected item. If more than one thing was selected,
' just get the first item and ignore the rest.
Dim oSelectedEnts As Inventor.ObjectsEnumerator
oSelectedEnts = oSelect.SelectedEntities
If oSelectedEnts.Count > 0 Then
Pick = oSelectedEnts.Item(1)
Else
Pick = Nothing
' Stop the InteractionEvents object.
oInteraction.Stop()
' Clean up.
oSelect = Nothing
oInteraction = Nothing
End Function
Private Sub oInteraction_OnTerminate()
' Set the flag to indicate we're done.
bStillSelecting = False
End Sub
Private Sub oSelect_OnSelect(ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, _
ByVal SelectionDevice As Inventor.SelectionDeviceEnum, _
ByVal ModelPosition As Inventor.Point, _
ByVal ViewPosition As Inventor.Point2d, _
ByVal View As Inventor.View)
End Sub
End Class
Replies (8)
Message 2 of 9
sanjay.ramaswamy
Do you have any other dialog or a form up at the time? If so, try without the dialog. Also, if you are on Inventor 2011, try the new CommandManager.Pick method - that will significantly simplify your code.
Message 3 of 9
matt_jlt
Hi Sanjay, i can't go to 2011 yet as my office has not migrated. There are no other forms or dialogs open. I have a simpler example if the one i used is too complex. It's basically just the selection class straight from the inventor programming help menu and I just can't get it to work, I am using vb.net & Inventor 2010.
Thanks, Matt.
    Public Sub Detail_Item()
        ' Call the Pick method of the clsSelect object and set the filter to pick any face.
        Dim oView As DrawingView
        oView = oSelect.Pick(SelectionFilterEnum.kDrawingViewFilter)
        ' Check to make sure a face was selected.
        If Not oView Is Nothing Then
            MsgBox("View Selected", MsgBoxStyle.Information)
        Exit Sub
    Private WithEvents oInteractEvents As InteractionEvents
    Private WithEvents oSelectEvents As SelectEvents
    Public Function Pick(ByVal filter As SelectionFilterEnum) As Object
        ' Initialize flag.
        oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents
        ' Ensure interaction is enabled.
        oInteractEvents.InteractionDisabled = False
        oSelectEvents = oInteractEvents.SelectEvents
        oSelectEvents.AddSelectionFilter(filter)
        ' Start the InteractionEvents object.
        oInteractEvents.Start()
            ThisApplication.UserInterfaceManager.DoEvents() ' Can't Get Past This Loop!!!!!!!!!!!!!
        Loop
        Dim oSelectedEnts As ObjectsEnumerator
        oSelectedEnts = oSelectEvents.SelectedEntities
        Else
            Pick = Nothing
        oInteractEvents.Stop()
        ' Clean up.
        oSelectEvents = Nothing
        oInteractEvents = Nothing
    End Function
    Private Sub oInteractEvents_OnTerminate()
        ' Set the flag to indicate we're done.)
    End Sub
    Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As Inventor.View)
    End Sub
End Class
Message 4 of 9
I would imagin this line is showing up as a error in VB.Net?
You need to use the Inventor.Application instead of ThisApplication.
Also for DoEvents if it isn't in a form, I think you need to use something like this
System.Windows.Forms.Application.DoEvents()
But even with that I remember fussing with the selection routine for a while and never getting it to work right in .Net.
Message 5 of 9
matt_jlt
Thanks Kent but I have already tried your suggestions and I forgot to include the imports and declarations for the "ThisApplication" to work, I have searched google and the forums, is there no way around this problem?  This is driving me nuts.
Regards, Matt.
Message 6 of 9
matt_jlt
If no one can work out what's wrong, could someone please post a working example of simple selection in vb.net for me? I'm completely stuck and almost all of my addins require a selection process.
Thanks, Matt.
Message 7 of 9
matt_jlt
Hi guys, I'm still stuck on this same problem? Someone out there has to have a solution for this (other than upgrading to inventor 2011)? Please help.
Message 8 of 9
You can try this. It will work, but needs some fine tuning.
Wim
    Private WithEvents oInteraction As InteractionEvents
    Private WithEvents oSelect As SelectEvents
    Public Function Pick(ByVal filter As SelectionFilterEnum, ByVal oAppOselect As Application) As Object
        ' Initialize flag.
        oInteraction = oAppOselect.CommandManager.CreateInteractionEvents
        Loop
        Else
            Pick = Nothing
        oInteraction.Stop()
        ' Clean up.
        oSelect = Nothing
    End Function
    Private Sub oSelect_OnSelect( _
        ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles oSelect.OnSelect
    End Sub
End Class
Message 9 of 9
matt_jlt
Thankyou so much Wim. It finally works. I've spent so many hours trying to work out this problem i was starting to go a little crazy. Thanks again.
