Try runnning these from an Inventor Macro. You would need to change the way
the document and Inventor arre referenced if running via VB or VBA from
another app
Public Sub testDXF()
Dim oDoc as document
Set oDoc = ThisApplication.ActiveDocument
Dim addIns As ApplicationAddIns
Set addIns = oDoc.Parent.ApplicationAddIns
Dim dxfAddIn As TranslatorAddIn
For i = 1 To addIns.Count
If addIns(i).AddInType = kTranslationApplicationAddIn Then
If addIns(i).Description = "Autodesk Internal DXF Translator"
Then
Set dxfAddIn = addIns.Item(i)
Exit For
Next i
'Activate AddIns
dxfAddIn.Activate
Call createDXF(oDoc.Parent, dxfAddIn,"c:\temp\test.dxf")
End Sub
Private Sub createDXF(oApp As Object, dxfAddIn As TranslatorAddIn, fname As
String)
Dim map As NameValueMap
Dim context As TranslationContext
Dim trans As TransientObjects
Set trans = oApp.TransientObjects
Set map = trans.CreateNameValueMap
Set context = trans.CreateTranslationContext
context.Type = kFileBrowseIOMechanism
Dim b As Boolean
Dim file As DataMedium
Set file = trans.CreateDataMedium
b = dxfAddIn.HasSaveCopyAsOptions(file, context, map)
file.FileName = fname
'specify ini file from where the setting will be pickup
map.Value("Export_Acad_IniFile") = "d:\temp\dxfconfig.ini"
dxfAddIn.SaveCopyAs oApp.ActiveDocument, context, map, file
End Sub
