translate Iproperties ? with google translate ?
Darkforce_the_ilogic_guy
Advisor Advisor
I found this code that some other use to translate  text in an other program ... is it possible to somthing like this in inventor ?  maybe make an marco that will traslate descition form danish to english ? and ask user if they want to replace the text with the english version?  best if it possible to make change before replacing sind google tralsate is not prefekt
Sub test()
    Dim s As String
    s = "hello world"
    MsgBox transalte_using_vba(s)
End Sub
 Function transalte_using_vba(str) As String
' Tools Refrence Select Microsoft internet Control
    Dim IE As Object, i As Long
    Dim inputstring As String, outputstring As String, text_to_convert As String, result_data As String, CLEAN_DATA
    Set IE = CreateObject("InternetExplorer.application")
    '   TO CHOOSE INPUT LANGUAGE
    inputstring = "auto"
    '   TO CHOOSE OUTPUT LANGUAGE
    outputstring = "es"
    text_to_convert = str
    'open website
    IE.Visible = False
    IE.navigate "http://translate.google.com/#" & inputstring & "/" & outputstring & "/" & text_to_convert
    Do Until IE.ReadyState = 4
        DoEvents
    Loop
    Application.Wait (Now + TimeValue("0:00:5"))
        DoEvents
    Loop
    CLEAN_DATA = Split(Application.WorksheetFunction.Substitute(IE.Document.getElementById("result_box").innerHTML, "</SPAN>", ""), "<")
    For j = LBound(CLEAN_DATA) To UBound(CLEAN_DATA)
        result_data = result_data & Right(CLEAN_DATA(j), Len(CLEAN_DATA(j)) - InStr(CLEAN_DATA(j), ">"))
    Next
    IE.Quit
    transalte_using_vba = result_data
End Functions
yana.mayami.87
Community Visitor
Community Visitor
It is very interesting. I tried to make a translation through google translator, but I did not understand anything. Could there be translation errors? latin - programming language, and I want to use this translator www.translate.com/latin-english It is paid, so I have more hopes that the translation will be more accurate, besides, here the machine translation is manually checked by specialists. I think that this is the right decision since I did not get accuracy in translation from Google translator.
